09-14-2024
05:15 AM
- Mute
- Permalink
- Report
09-14-2024
05:15 AM
I think this is as close as you'll get. Edit needed to change the tip rad to 0.1mm, reuploaded file.
First setup a small custom tip.
Then setup the holder like this. I used the download from the page you linked to get the sizes. Note the cut width is from the centre line of the reduced section of the boring bar to the tip tangen and you can only set the size of the reduced section in Fusion (2.3mm). See attached file, tool is stored in the document's tool library.
Mark Hughes
Owner, Hughes Tooling
Fusion
