traditional.builds
175 Views, 2 Replies
Machine a sphere with a groove down the center
Any idea on how to machine the center "slot" of this half sphere?
I have tried a few different 3D / 5-axis toolpaths to some success, but I was wondering if there was a simpler way to do it?
I am playing with the Multi Axis Extension for another week while I still have the trial and wanted to test out some simple things, to see how I could incorporate it into more intricate jobs.
I used a 2D roughing operation to clear the bulk (assuming it will be cut from a square stock) and then used a 3D spiral with a ball to get the outer sphere shape, I just need help with the center slot. It does not need to be perfect.
Right now, I am not worried about tool/holder collision with the base stock. I am just looking for the appropriate way to machine this. I will deal with stock/collision stuff when it comes to the actual machining.
Thank you in advance!
If you have a 5 axis machine I would use a swarf toolpath on the slot walls.
A multi axis toolpath with a "to point" (center of sphere) direction comes to mind, as well as the advanced swarf like your wavey flag.
Please click "Accept Solution" if what I wrote solved your issue!
