natesh_rvce
in reply to: natesh_rvce
Wow! Thank you for helping me out here. I thought that the separation was exactly 0.5 inch and it should have matched the tool diameter also 0.5 and therefore worked for milling.
I will explore the "slot" option; this example was to illustrate the problem I was having with selecting concentric pieces in general. I have more complicated scenario where the slot option does not work.
"I have just seen that your workpiece is not connected to each other, which is not exactly helpful either" : This was the issue! Thank you I should have spotted this!
