therealsamchaney
217 Views, 1 Reply
Can't select stock bottom in 2D bore operation heights
I'm just trying to do a simple 2D bore operation to bore out a few holes. I want the bore to go to the bottom of the stock because I will use it for fixturing for the second op. However, I can't select stock bottom when setting the bottom height in the heights tab for some reason. The option is just there. I have checked the stock thickness and origin and tool flute length and there should be no conflict. The endmill tool should easily be able to bore all the way through the stock. Why is this option missing and how do I get it back on the drop-down? Is it just never an option for 2D bore, and if so why? I feel like it would be a common bottom height for boring operations
