07-11-2024
11:13 AM
- Mute
- Permalink
- Report
07-11-2024
11:13 AM
Hi
Yes for all roughing toolpaths/passes fusion doesn't output Cutter compensation so the toolpath will be all in R0
2D Adaptive is a Roughing toolpath and shouldn't be used to finish anything.
You should follow up with a 2D contour pass to finish(you can also use 2D Pocket with Finishing passes turned on)
Set the Compensation type to In control:
Now the Finish passes will be output with RL(Climb milling) and the DR will have an effect on the size
Fusion
