07-03-2024
04:21 PM
- Mute
- Permalink
- Report
07-03-2024
04:21 PM
Hi
I have an idea using Steep n shallow.
You cannot create passes greater then the Flute length(Saw thickness) so say its a 4mm saw, you set the stepdown to 4mm and you get a toolpath like this
Then using delete passes
select every 5th line
then invert the selection and delete all the other passes
This should follow all the 3d contours of the part while making the slices
Fusion
