- Mute
- Permalink
- Report
Hello all, I've run into an issue that I have not seen addressed after searching through the forums. I am trying to program cutting a small undercut o-ring groove as shown below using this face grooving tool (link) held at a 45 deg angle.
When creating the tool, you have the option to orient it at a 45 deg angle, however then the tip tangent point is wrong (for a fixed 45 deg angle at least) and the tool is not valid for most toolpaths (this error). So I created the tool as a standard round insert tool at the standard 0 deg orientation and omitted the holder, but it will not groove in Z even with "Allow radial and axial grooving" selected (second image). Maybe that is because it is a turning general tool, but trying a grooving tool does not work because they cannot be defined as just a circle, they have an extension and again cannot be oriented at 45 deg in the tool setup. The option to change the orientation for the operation does not appear and I am not sure it would be correct for the compensation point.
Thanks in advance for any help you can provide!
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
I believe you have to program it using the tools radius/center point and not tip tangent because they still haven’t fixed this yet. Just offset to tool accordingly in your machine’s control after touching off the tool.
- Mute
- Permalink
- Report
Thanks very much, tool centerpoint does help get a toolpath generated using the 45 degree orientation in the "Turning Groove" operation. However because the orientation is set in the operation, I can't use the same 45 degree orientation in any normal roughing operations. Doesn't really matter in this case that the tool is shown at 0 deg in other operations but might matter for more complex parts/machines.
Fusion
