drantanen
in reply to: seth.madore
Thank you for the quick reply Seth.
When I select Compare and Edit and look for the Calculation Tolerance parameter, I see it's red, with a value of "tolerance-surfaceTolerance".  When I change the value to 0.001" it was able to successfully generate a toolpath as expected.
I would bet that you're correct in saying that an update scrambled some of the hidden default values.  I have saved my current parameters as default so I should be good to go now.
Thanks again for your help Seth!
