seth.madore
in reply to: drantanen
Right click on your toolpath and select Compare and Edit. Type in the words "Calculation Tolerance". What is that value set to? What happens if you change the value to a lower one. With a toolpath tolerance of .002" (as shown in your image), I'd expect to see .001".
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
It's possible that an update may have scrambled some of your "hidden" default values. It's possible for another user (such as myself) to provide you back with a working toolpath and for you to right click on toolpath and "Save Parameters as Default".
Seth Madore
