- Mute
- Permalink
- Report
Hole recognition not finding spot drill
I am building templates for tapping holes, and when i pull the template in manually it brings in the tools as expected. When i run hole recognition, it finds the drill, and tap, but the spot drill is empty. I even put the drill into the same library and selected those when i ran it, it comes up with no tool.
Template:
i select this library which contains all of the tools that are in the template.
This is what i get
Why is it not seeing the tool? Any help would be great, Thanks.
- Mute
- Permalink
- Report
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Hmm, it worked fine for me when selecting "Spot/Drill/Tap"
Could you export and share the Template file that you're using?
Seth Madore
- Mute
- Permalink
- Report
That doesnt pull in the right tools. I have created templates for cutting taps, and roll forming, and all the corresponding tap drills inside them, because hole recognition cant decipher the drill size difference compared to standard.
Im selecting my 4-40 template under Cloud/TAPPING/ROLL FORMING - INCH. And then selecting the tool library for my roll forming taps, which contains all the necessary tools for the operation.
Fusion
