I'm having a similar issue. Let me know if you want a new post.
Setup model:
Results with rest machining enabled [air cuts nothing inches away from part/stock]:
Results without rest machining [as expected]:
Toolpath was copied from this toolpath from a different setup:
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
