05-28-2024
12:30 PM
- Mute
- Permalink
- Report
05-28-2024
12:30 PM
I need some help with a tool path. I'm machining an o-ring groove with an offset drop hole using a Parker-Hanifin cutter from Harvey Tool.
Obviously, I want to start and stop at the center of the drop hole; I'm able to get the inside of the tool path to work however not the outer. When I attempt the outer it ignores the predrill start/stop location and plunges in the center of the groove.
I've tried all I can imagine to get it to work; I've attached the file so you can have a go at it. Thank you in advance!
Sincerely
Dale
Dale Speakes
prototype technology
Fusion
