- Mute
- Permalink
- Report
I have a step file from the builder of my machine.
When imported this step file in fusion this is very detailed.
How can i adjust this file (les detailed) to use for machine simulation?
Is there an easy way to remove the smal not used components?
- Mute
- Permalink
- Report
It's going to be in the Design environment, for starters.
Tools like Simplify are going to be your friend, but it is going to be a laborious process, depending on the level of complexity.
Seth Madore
- Mute
- Permalink
- Report
Thank you for the info, perhaps it is better to import the most important parts into a new assembly.
The machine simulation worked with the imorted step file, this was only very time consuming, but looked very good.
And i could not get the tool attach point right.
Attached a picture of the machine.
- Mute
- Permalink
- Report
If you want to introduce your machine to Fusion and adjust its kinematics, I can help you. I can also remove unnecessary areas.
Fusion
