BWENGUK
499 Views, 8 Replies
New "Order For Shorter Links" doesn't seem to work as intended?
Just trying out the new "Order For Shorter Links" which is something I've been wanting for ages. But it doesn't seem to work how I would have expected it too. This is a very basic example, but I have a 50mm tool set to do 20mm stepovers. The first 'front' cut is correct, however the second 'back' cut ends up doing pretty much a full width of cut, ignoring the 20mm step over.
I assume it is essentially just generating the old style tool path which works from one side across, but then changing the order of the cuts? Rather than creating a new tool path that should be working from each side in, until it meets in the middle.
I have added some screenshots below. Hopefully this makes sense. I was looking forward to this new toolpath, but as it's currently implemented, I can't see it being useful at all, as you seem to have no control over that cut at the back!
