Hi
the problem is with the boundary selections, there are multiple face selections which are causing the tool to lead in/out in odd spots
If you select one single closed boundary, change the Tool Containment to "Tool center on boundary", Turn on Contact point boundary and set the additional offset to -tolerance it will work properly
I was going to suggest using the Blend toolpath but you have some tiny mismatches in the fillets which will mess up the drive curves
