eerier_bleach0f
468 Views, 5 Replies
3D Adaptive: Tool mills lopsided + no tooltips?
Ok so here's the model [Yes I know this would be better in a lathe] and stock for the first setup:
Here's what the stock looks like when setup 1 is complete:
Here's the stock settings for setup 2:
Now in setup 2 I have a 3D Adaptive toolpath. No matter what stock definition settings I choose the tool will not do what I need it to do.
If I choose to define the stock as "Stock contours" and check off "Use setup stock silhouette it does mill what I need it to but it's 95% air cutting:
If I choose to define the stock as "Rest" without "reduce air cutting" checked the tool air cuts a lot and mills the part lopsided like it's trying to stay away from one side. This results in extra stock on one side:
Screenshot 2024-05-17 at 11.49.51 AM.pngScreenshot 2024-05-17 at 11.50.03 AM.pngScreenshot 2024-05-17 at 11.50.13 AM.png
If I enable "reduce air cutting" there is no more air cutting, but it actually leaves more extra stock on one side:
Tooltips never pop up for these rest machining settings so hard to tell exactly how the new settings work. I just get the mini ones that are redundant text:
Any ideas what's going on?
Rest of the operations settings:
Screenshot 2024-05-17 at 11.58.39 AM.pngScreenshot 2024-05-17 at 11.58.46 AM.pngScreenshot 2024-05-17 at 11.58.51 AM.png
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
