jscott6SWZG
in reply to: martha.deans
I guess what i am asking is
say i have 1/4 bit and the speed in the selected material is say 7600 rpm.   When i go to the 1/8 bit the speed is 11999 rpm.  If you were to maintain the sfm the same as the 1/4 inch bit the speed should be 14200 rpm.   So i increase the rpm.   But for that rpm.  I should have an increased feed.   I guess i should maintain a constant feed per tooth.
Is this the proper math.
So then i do this for say each bit and material manually. That is may be 30 times.
So i  save each tool to my personal library and then upload that to the cloud?
