Hard to really see what's going on, but you should be able to draw the shape on a flat plane, then wrap the toolpath in 2d contour. You will want to use 2d contour as you would "trace". Basically set no radial tool compensation.
I'm currently doing it without issue, however my machine had an issue with it going on both sides of 0/360 degrees, so I had to change my orientation, basically putting the toolpath on the "backside" of the part, so it would play around between 0 and 360 degrees, and not have to cross that boundry of 0/360 degrees, because it would want to "unwind" while in the cut, which was bad!
