davidewingJ9PZ3
179 Views, 0 Replies
Bore Milling Cycle sequence of start moves Fusion v Machine
In fusion , the Bore Milling cycle goes to 'retract height', then moves on XY, then goes to 'feedheight' before beginning the helix.
On all my machines, the machine cycles go to 'retract height, then 'feedheight', then move on XY before beginning helix.
I use Heidenhain Cycle 208 & I have macro cycles on Fanuc using G66
I use this cycle sometimes for milling undercuts, on Fusion is crashes into the holes, but i know in reality on the machine the XY will not move until the tool is in position. (the machine cycles arc on from the centre of the hole when at 'feedheight'. Fusion does not arc on at all)
Would Fusion be willing to review/change? or create an option within the cycle to stay on hole centre point until it goes to the 'feedheight'?
