rw_skinner
364 Views, 4 Replies
VMC - Facing Patterns
I'm trying to get my facing pattern where the overlap is in the center of the Y.  This part will be cut in half and I was trying to get the patterns even on each half.    Face Mill is 2.5" and the Parts is 2.8" in the Y dimension.
The first pass is fine, but the second pass is overlapping way too much.  I tried to have some lines for it to follow but it doesn't work as expected.
Can I do this with a facing operation or would it be easier in a 2D profile tool path?
2D contour, select 2 single line segments and use -stock to leave to get the overlap how you like.
Please click "Accept Solution" if what I wrote solved your issue!
I ended up doing that but I had to create 2 2d contours operations and select a single line for each op.
I hate to say it, but even the most basic cam programs will let you select a 2d path OnCenter, Outside, Inside, and direction.  I found how to do tangental, and direction but how do you draw a line and tell the tool path to stay on the center of that line?
a.laasW8M6T
in reply to: rw_skinner
Hi
For 2d Contour you can set the compensation to "off"
Alternatively you can use the Trace toolpath which is set to center by default
rw_skinner
Ah, I forget about trace.
