HughesTooling
in reply to: seth.madore
@seth.madore wrote:
@HughesTooling wrote:
Just remembered, I'm pretty sure this graphic is wrong, it should be like I've sketched in red.
For...insert size? Is that accurate, isn't it the Inscribed Circle? (either way, the current graphic would be wrong)
The Inscribed circle is 6.35mm for this size tip, this would work the way the graphic is but then the size in the menu's wrong.
Mark Hughes
Owner, Hughes Tooling
