HughesTooling
in reply to: seth.madore
@seth.madore Another problem I ran into a while ago, I needed to bore a undercut and keep the corner as sharp as possible. The only tool I could find was a small internal threading boring bar (See here, the picture on the page is wrong, it's a 60°with a 0.05mm corner rad). I set the tool up as an internal threading tool but Fusion wouldn't let me use it for profiling, don't see why this should be blocked no real reason why you can't turn with a thread insert.
In the end I had to set it up like this.
Mark Hughes
Owner, Hughes Tooling
