HughesTooling
in reply to: seth.madore
This is the tool I used. I ground away the end of the holder so I could touch off using the tip. I guess I could have measured from the end of the holder to the tip midpoint on a shadowgraph but would have been a bit fiddly centring on the tip.
@seth.madore wrote:
So you would hope/expect that we allowed ID tools to be defined differently (for Tip Tangent points) than OD tools, when insert is set to neutral?
I guess having it consistent for ID and OD is best in the long run but what is going to happen to existing toolpaths? If there is going to be a change in how it works will there be warnings the tangent point has changed? You'll need warning when creating new toolpaths with an existing tool and warning if you regenerate existing programs.
Mark Hughes
Owner, Hughes Tooling
