eerier_bleach0f
286 Views, 1 Reply
Simulation: False positive collision
There is no collision but Fusion says there's 2 per bore at different points:
It's close at one point but there's no collision.
Screenshot 2024-05-03 at 1.07.01 PM.pngScreenshot 2024-05-03 at 1.07.05 PM.pngScreenshot 2024-05-03 at 1.07.10 PM.pngScreenshot 2024-05-03 at 1.07.14 PM.png
Top height is below the top of the bore, BUT 5 thou above the bottom height of the previous bore toolpath. It's plastic so I want to remove the stringy chips before continuing boring the hole, I have 4 bore toolpaths all milling progressively deeper but always starting 5 thou above the previous bore's bottom height. All 4 have false positive collisions.
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
