engineguy
in reply to: liz.radoy
@liz.radoy
You can try leaving the bolts as part of your Model and then just selecting the Pink area and using  2D Pocket toolpath which should go around the Bolts treating them as Islands. See example image below for a guess at what you are asking for. If yes the see attached example file
