hphanQ726A
in reply to: seth.madore
Mine is NGC ST35Y twin spindle, it needs the D-comp to control the wear, I try to put negative values to correct the dimension, but it does not affect at all, but when I manually insert the D-comp after then it does work.
I use Mastercam and Esprit for many years (14+ years) and it always output G41 X-value Y-value D-value on both turning and end mill tools, but Fusion does not. Sometimes we need to use same tool but to control other dimensions, so the D-comp is really needed.
Oh, it does not output the D-comp on the turning tool too. it should. For an example, if we bore a hole more than 2" which sometimes we got the tapper issues then we should use the different D-comp to control the front and back.
