kevinFZF99
in reply to: a.laasW8M6T
Automatic In-process Stock generation is On.
Display In-Process Stock is on.
No matter what is regenerated or how many times the computer is restarted, Fusion does not generate the IPS. Every process in 4 different setups contains the Green check inside a dashed circle.
Simulation works if it is started from the first Process. Somehow, it calculates processes with "rest machining" despite the lack of IPS.
It was working on Friday. Now its Monday and it no longer works.
