Attached is a sample Fusion file as well as the Dump post output, using the latest Dump post.
Ill use T3, a spot drill, as an example, lines 380 to 385:
  tool.insertType=3 (TURNING_INSERT_ISO_C)
  tool.holderType=0 (TURNING_INSERT_USER_DEFINED)
  tool.compensationMode=0 (TOOL_COMPENSATION_INSERT_CENTER)
  tool.inscribedCircleDiameter=0.39370078740157477
  tool.edgeLength=0
  tool.noseRadius=0.03937007874015748
those values are of course not applicable to a spot drill.
(I am guessing that because the tool type Spot Drill doesnt have values for tool.insertType, for example, that the value is not being overwritten by the new tool, and also not being set to 0. I found this out when working with the Excel setup sheet post, so this is probably coming from the Fusion side).
