03-29-2024
12:42 PM
- Mute
- Permalink
- Report
03-29-2024
12:42 PM
For the Rotary contour, being that it is a Finishing toolpath there are no helix or ramping options, You could use a 2d contour to helix a hole in first where the tool will lead in.
I'm assuming you don't want to mill away all the material, just mill around and drop the chunks out, otherwise I would suggest using 2D adaptive with wrap.
For back deburring I haven't been able to come up with a solution that works with a lollipop but you can do this quite easily with a double angle chamfer cutter and use 2d contour with wrap.
see attached
Fusion
