HuntleyBill
344 Views, 5 Replies
Parallel is set to 2mm depths but plunges 8-10 mm on first pass. How can I correct this?
On the attached file, the first Parallel operation is plunging the first pass way too deep. I have it set at 2mm multiple depths. The simulation shows it makes 2 passes. No matter what I set the pass depth to be, it sets the number of passes to 2. When I start to mill the model (using styrofome as a test stock)it plunges to 8-10 mm to mill the first pass. The second pass is milled at the correct 2mm depth.
How do I set this up so that is mills no more than 2mm depths for each pass?
Thank you for your advise.
Bill
