in the 4th tab, lower (smaller number) your tolerance, and change the Minimum Stepdown to a greater value you will remove those.
in the 5th tab, change Stay Down Level to Most and use Minimum Retraction.
Please click "Accept Solution" if what I wrote solved your issue!
