a.laasW8M6T
in reply to: risa_vedoya
Hi
It seems you are using one of the Sample machines from the Fusion library in your setup.
These machines have a "Machinesimulation.cps" post processor which cannot output real code.
you need to select an appropriate post processor for your particular machine to post real code.
Can you tell us
  1. What your machine Brand and model is?
  2. What the controller Brand and model type is?
It would also be helpful if you could upload your Fusion file here.
Go to File>Export>Save as .f3d/.f3z
