- Mute
- Permalink
- Report
I recently got a new to me Haas VF2 with NGC, for years I have been using Fadal mills with both Fadal and Fanuc controls, and the posts have always had a radio button to click to enable G95 (IPR) feedrates. The NGC post does not have this. Can someone modify the post, or explain to me the steps needed to take, to add G95 as an option not just for tapping but for everything.
Thanks in advance for any help.
- Mute
- Permalink
- Report
You have to look in the post properties under preferences and check the box.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
then you are looking for G99 to set your feedrate.
- Mute
- Permalink
- Report
G94 is IPM
G95 is IPR
I just want to know how to get a check box to turn on IPR for all tools,
not just tapping.
- Mute
- Permalink
- Report
You need to be more precise then with "everything". You mean all canned cycles. FYI you can still program as IPR inside fusion and allow it to post out in IPM.
https://www.haascnc.com/service/codes-settings.type=gcode.machine=lathe.value=G99.html
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
For example, if you look at the Fanuc post, you will see in the preferences tab the seventh option down is simply titled "Use G95"
Can this please be added to the NGC post?
- Mute
- Permalink
- Report
Check the box on the tool tab. If you have the latest NGC post it will output the correct code.
- Mute
- Permalink
- Report
Look for this section in the post, if your not using the latest or you have a modified post.
- Mute
- Permalink
- Report
There is only one issue with this and that is that this option is available in drilling but not in milling.
I want to be able to post my entire program in IPR.
- Mute
- Permalink
- Report
As I said before
"then you are looking for G99 to set your feedrate."
- Mute
- Permalink
- Report
Fusion
