HughesTooling
334 Views, 6 Replies
Bug. Turning, still problem with negative stock.
I'd like to be able to start my cut off the part, this is quite easy using tangential extension for front and back faces.
But use a negative stock offset and you get this.
Part of the problem is the limit for the back face does not take into account the negative stock allowance. If I put a small offset for the back face I get this but that's not what I want. I want a toolpath like the first image just with a negative stock.
File's attached.
Mark Hughes
Owner, Hughes Tooling
