Tomas_V_cz
in reply to: a.laasW8M6T
1 BLK FORM 0.1 Z X-232 Y-15 Z-12
2 BLK FORM 0.2 X+2 Y+15 Z+0
3 CYCL DEF 32.0 TOLERANCE
4 CYCL DEF 32.1 T0.02
5 *-material:11523                   'job-notes' 1 line
6 *-zmena:A                          'job-notes' 2 line
7 *-poznamka:                         Program Comment
8 *-datum: streda, 6. brezna 2024     date of generation of the program with the name of the day
9 ;
10 *- zarovnat z prava X+0            'operation-comment'
11 ;
12 TOOL CALL 1 Z S2200; monolit 16
13 L M6
14 M3
15 L X+11.3 Y+20 R0 FMAX
16 M8
17 L Z+50 R0 FMAX
I need to get some data into the program - material - for example duralumin, stainless steel, etc... and the current change in the drawing. Fusion does not provide any global parameters that the postprocessor would write to the program. Our practice is that these data are in the program for various reasons - at a glance I can see if the program is up-to-date, what the material is. And this is the option to display this data in the program in the place that I want. Any idea how to get this data from Fusion other than writing it in this note?
And what is * - or ; It's just that the output in this part of the program was like this before. And that's how we like it. Other comments on operations are already with ;
the data "* -" is displayed in the right part of the screen of heidenhain 530 CNC machines - it is easy for the operator to quickly get to the desired place, because the operation lists are also with "* -"
