kegarc2002
210 Views, 2 Replies
Please Help Machining This Part
Hi guys:
Can someone please help me machine this part? I have 3 different issues.
1_Can't make it machine the bottom surface of this spiral "pockets".
2_I can't make the Trunnion to rotate and machine the part in the front of the table.
3_Am I using the right strategies to run this part?
Please, Maybe I am not using the right multi-axis strategy. I'm new in 5 Axis.
Thanks in advance.
a.laasW8M6T
in reply to: kegarc2002
Hi
To get the trunnion to face towards you, edit the machine definition and set the preference for the A axis to positive
To machine the floor of the spirals you can use Blend or Geodesic, I have attached a file with some examples.
Blend seems to give the nicest results in this case.
Using Rotary pocket and rotary contour is a good choice for roughing and finishing the walls of a part like this so you were spot on with those selections
kegarc2002
Thank you a.laasW8M6T for the help and the fast response. When I posted this part issue, I did it with you in mind.
I knew if you read it, you had the solution.
I'm gonna get into the examples files, I'll let you know if I get in trouble.
Thank you again for the help.
