Marco.Takx
in reply to: chrisevrard
Hi @chrisevrard,
A couple this you did wrong and forgot.
  1. Within the setups you have to define with WCS on the machine you like to use (Setup 1 set it to 1 (G54) and setup set it to 2 (G55))
  2. Then you can post both setups at once into a single nc program.
    And use the Reorder and minimal tool change. To make a optimal nc program without a lot of tool changes.
    But you first have to fix the tools into your programming.
    I see double tools that are the same.
    That means that the option Reorder and minimal tool change can't work because for him these are different tools.
    Also you have same tool numbers on different tools.
    Hopefully this makes sense for you.
    If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
