08-09-2016
12:18 AM
- Mute
- Permalink
- Report
08-09-2016
12:18 AM
I have got it working better, you will see what is different.
don't worry about the stock box point bug in the setup, I have set it in the tool paths to the stock box point where you want it.
it up dates correctly the toolpath stick to the stock, I set the stock in the setup as what you have set as stock it changes if you change stock size.
I have moved the sketches in with the model component, it makes it work a little bit better, trippy's R U L E 1.
I changed the contour to a 3D contour, it has only 3 toolpaths it's all that is needed
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
