08-08-2016
03:04 PM
- Mute
- Permalink
- Report
08-08-2016
03:04 PM
it's your model and the adaptive where the problem is, I have fixed most of it.
the setup just needs edit and hit ok the Adaptive loses focus.
also if you have it as one component so the sketches are with the body it will help as the model adjust it moves but the sketches don't move with it,
I have forced it to cut to the body by moving the bottom height plane. and using the sketch as the stock contours
.75 thickness
1 inch
if you re select the machine boundaries it comes good.
there are a few other problems with it when it's fixed I will post it back
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
