02-08-2024
04:14 AM
- Mute
- Permalink
- Report
02-08-2024
04:14 AM
Thank you for the help. I have posted the file. I had my tolerance set to 0.06, will try dropping to 0.005 on next run. Would you also use smoothing tolerance on this? Having looked at the Surface triangulation tolerance it was set at 0.03mm. what affects this figure or is it a manual change? My cycle32 was set at .1mm and "finishing", could it be that the tolerance was set too high on this causing issues as well?
Appreciate all the help.
Fusion
