DarthBane55
in reply to: FrodoLoggins
I thought I'd try, so when I generated the toolpath, just generating it, not doing anything else, it did a path somewhere else, see pic below:
So I deleted your chains and redid it, and it worked fine:
I have no idea why the chains were mirrored and moved from where they should be, but it looks to me like you should redo your chains.  Also there were 2 chains selected but I think it only needs 1, not sure what the 2nd chain was, it was exactly the same as the 1st chain when I imported your file.
