FrodoLoggins
126 Views, 2 Replies
SEMI-URGENT: Parallel: Generated fine Friday, now skips section
No missing sections in toolpath on Friday and this morning, now after making no changes to the model or toolpath settings the parallel toolpath just skips this section:
Screenshot 2024-01-22 at 10.28.52 AM.pngScreenshot 2024-01-22 at 10.30.09 AM.pngScreenshot 2024-01-22 at 10.30.18 AM.pngScreenshot 2024-01-22 at 10.30.23 AM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
DarthBane55
in reply to: FrodoLoggins
I thought I'd try, so when I generated the toolpath, just generating it, not doing anything else, it did a path somewhere else, see pic below:
So I deleted your chains and redid it, and it worked fine:
I have no idea why the chains were mirrored and moved from where they should be, but it looks to me like you should redo your chains.  Also there were 2 chains selected but I think it only needs 1, not sure what the 2nd chain was, it was exactly the same as the 1st chain when I imported your file.
seth.madore
Hmm, something's odd:
1) Your Containment boundaries are not quite what I'd expect, and a regeneration of the toolpath gets me this
What do you think about this toolpath?
The above was created just by doing a "Touch" on that one face
Seth Madore
