nubrandao
312 Views, 8 Replies
cant delete tool library
hi, im importing tool data base from powermil to fusion.
i imported  two data bases succes, one of them gave an error, appears in red and dont allow me to delete...its shows error "fail to import"
how can i delete? cant find the folder
jeff.pek
in reply to: nubrandao
Which section of the tool library did you import it into? Local? Cloud?
Jeff
nubrandao
in reply to: jeff.pek
local
jeff.pek
On Windows, the local tool library files are in %appdata%\Autodesk\CAM360\libraries\local.
Jeff
nubrandao
still cant find, my windows is 10 , since is in the company, maybe cant acess, there are lot of restricions
jeff.pek
I wouldn't expect that area to be restricted. It would be under c:\users\<userid>\appdata\roaming.
Jeff
nubrandao
i will try it tomorrow..what files should i delete? what type of files extension?
jeff.pek
They would typically have a ".json" extension.
nubrandao
fixed..was in roaming folder.thanks
