614 Views, 1 Reply
Converting Machined stock into a body
Hey F360 and others,
I was wondering if fusion has a feature that will allow you to after you have given tool paths and machined a stock down a rough part, to then take that rough part/stock and turn it into its own body. Ideally I would like to machine the stock down to a rough part. Then take that rough part, rotate 90 degrees and machine away to rough areas. FYI, it is not possible to clear the part to its desired without rotation.
Thanks!
