- Mute
- Permalink
- Report
Thanks for the response!
Well, the bug demonstrated in my example is actually more severe than that - the only way that I found to (temporarily) repair the glitch is save the project, close it & then reopen it. If you have slow Internet (I do), this can take forever, especially when you are working on a fairly large project. This is an incredible pain especially when fine tuning a design, which (for me) often involves switching back & forth between Model & CAM modes, if every switch requires a save-unload-load procedure.
Also - and I probably should have mentioned this in my original post - I suspect that the issue demonstrated by my example shows just the tip to the iceberg. As I stated in my original post, I am a huge fan of User Parameters, and use them frequently to reconfigure my designs. For months, I have struggled with my designs, as changes to the configuration (via User Parameters) would result in all sorts of bizarre behavior - and this occurs on the Model side as well. For a long time, I assumed that all of the problems were due to my designs not being set up correctly. To that end, I have recreated several large projects several times, to clean up & simply the designs as much as possible. This actually did fix a number of issues which were caused by mistakes in the design, but a number of issues have persisted. Yesterday, I happened upon a specific situation that could be easily demonstrated, and was clearly a bug - so I decided to document that instance. I sincerely hope that when the F360 gurus dig into this, they will take a comprehensive look at the whole thing.
Fusion
