- Mute
- Permalink
- Report
@raptessmistfyre wrote:
Ok, so correct me if I am wrong (again) ..
Machine Home is set when I power the CNC on, to the current XYZA positions ? ..
This is seperate from where I set the XYZA Zero position when setting up for a job.
G28 command, refered to Machine Home and Not the Zero I set ..
G28 will move to Machine Home, then proceed to the starting position set in the milling code ..
So as long as my Machine Home is set away/above the stock, it will not cause crashes into the material when G28 is called ?
This is correct and a lot safer than using a relative offset above the stock. If you have tool changes (change from a short tool to long) you can make sure the longest tool clears using G28 where you could have problems using part offsets.
Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
