- Mute
- Permalink
- Report
Ok, further testing done .. Still no solution ![]()
When using the 'Clearing' mode on Post Processing, it gives an error for any machining that is done at any angle other than Zero .. So this method is not an option for rotary toolpath ..
Error: Safe retract option 'Clearance Height' is only supported when all operations are along the setup Z-axis.
Error at line: 1139
Error in operation: 'Face 90'
I have attached the actual file I am trying to process, If you (or anyone) is willing to take a look at it and see if I have done something wrong, or if you can tell me how to change the Z0 from Rotary Center, to Stock Top, or anything else that may help in resolving this problem ..
The extra strange thing about all this, is that I have already used a previous version of this task and it worked just fine. Although I had a different (wrong) tool selected for it and since I changed the tool to the correct one and then regenerated the code, it hasn't worked for me since ![]()
Fusion
