@raptessmistfyre wrote:
Hi, sorry, yes I am using Mach3 post processor.
But why is it in the program, when the home position for my Rotary is 22mm below the surface of the material ?
How do I set a Z0 position to the top surface of the material, instead of the center of the rotational axis ?
IF you have no limit switches and no machine home position set there is an option on the post dialog shown in my first reply to use the clearance height. I would still recommend setting a home position though and use G28 as that is the safest option.
Mark Hughes
Owner, Hughes Tooling
