- Mute
- Permalink
- Report
Problem using User Parameters with CAM/2D Contour
There is a bug in F360 that has been around for awhile, but seems to have gotten worse with the latest update.
First of all, I use User Parameters A LOT. I'm a woodworker (using a 4-axis PCNC 1100 mill). The stock that I use varies somewhat from piece to piece, so I use User Parameters to enter the the precise size of each blank, along with any of a number of parameters related to the final desired outcome for that piece. When I enter all of the appropriate parms correctly, my model automatically resizes/reconfigures per my specs. This is AWESOME!.
Now, the bug: (I have attached a copy of a simple design & a Screencast that I created to show the problem). In my design, I have a User Parameter which specifies the finished thickness of my model. When this parameter changes, the model thickness changes appropriately, also a Sketch which is driven by the perimeter of the model adjusts to match. (This Sketch is used to define the toolpath for a 2D Contour operation on the CAM side)
When I first load the design, everything looks & works as expected: The components & Sketches match the User parameters & the CAM operations work correctly. Then I make a single change: adjust the User Parameter for the model thickness, and everything at first looks fine - the models & Sketches adapt as expected.
When I switch to CAM mode, problems are immediately evident:
1 - When I click on the Setup button, the Setup origin appears to have moved (from the right rear corner to the right front corner)
2- When (after regenerating toolpaths) I click on the 1st 2D Contour operation (driven by the adjusted Sketch) the toolpath displayed is completely goofy.
3 - When I select edit for the Setup, the Setup origin displays correctly (right rear corner). If I just click OK (no changes), then click on the Setup button again, the Setup origin now looks OK.
4 - When I select Edit for the 2D Contour op & select the Geometry tab, various things can happen; sometimes, it indicates that there is no curve selected, other times (as shown in the screencast) the selected path no longer follows the Sketch that is supposed to be driving it. Instead, it is actually showing the path of the Sketch BEFORE it was changed via the User Parameter. Hmmm.
5 - If I clear the current path selection & attempt to select the Sketch, clicking on the visible Sketch again causes the OLD toolpath to appear.
6 - Finally, if I save the the design (only change was the one User Parameter), close the design & reopen it, I can now go into the 2D Contour operation, reselect the Sketch & now everything works fine - until I attempt to adjust the User parameters again.
Fusion
