thespaltydog
324 Views, 3 Replies
Rest machining not recognizing stock left by 2D adaptive
Hey everyone,
I was cutting these parts out and noticed originally that my 2D adaptive wasn't cutting my dog bones in the corners of the interior pockets. I went to add a 2D contour and that seemed to do the trick, however, I wanted to try and use rest machining so that the 2D contour only does the corners. However, for some reason, it shows it as an empty toolpath and won't generate. I looked around and saw that it could be because my tool diameter was the same as the previous one so I tried sizing it down but that still gave errors.
I slightly oversized my dogbones so a .25 diameter cutter would do the job, so I'm not sure why the 2d adaptive isn't picking it up in the first place but if anyone can help me figure that out, or how to get the rest machining to work on my 2D contour I'd greatly appreciate it!
Labels (4)
